William Lupton wrote:
> Ralph,
> Re how to control initialization of output records:
> >3. PINI = YES, DOL is not set
> > Read back the variable value at startup. (I.e. the application set it
> > to some meaningful value before record initialisation.)
> So, the variable value is read back at startup only in the last case. So
> this could happen inadvertently if:
> a) there is a tool out there which defaults DOL to "not set" rather than to
> "constant zero" (we agree that Capfast is not such a tool; maybe there
> are no such tools)
> b) someone has previously created a database with DOL set to an empty or
> blank string (which will be interpreted as "not set") and has _intended_
> that to be the initial value written (this would probably be unintentional
> for anything other than a stringout?)
As regards (a), there is definitely a tool out there, it's called DCT.
At least in the newest version it does not initialize DOL to anything if
you don't explicitly specify so. I'd say that defaulting DOL (or any
other link field) to "not set" is the correct behavior since 3.13, at
least that's what the release notes suggest.
So, IMHO, case (a) is the rule rather than the exeption. Case (b) should
be regarded as an error in the database design, at least for databases
that are supposed to be 3.13 compatible (see, again, release notes for
R3.13).
I want to add a remark on Capfast: Neither the program itself nor the
conversion tools have any defaults for record fields. It's the symbols
(*.sym) and the edb.def that determine which fields are set by default
and to which value. The old behavior was to initialize all link fields
to something like "0.000000000" (lots of "0"s, never understood why).
To make Capfast compatible with 3.13, I went through the work of
adapting the symbols and the edb.def for R3.13.1 (or whatever release
number actually introduced differentiating between "0" and "" for
links). The changes (i.e. throwing out any defaults with a zero value)
can be done automatically with little perl script.
Ben
The Notorious Neb Nesknarf
- Re: VxWorks global variable device support William Lupton
Re: Python/CA Noboru Yamamoto
Re: VxWorks global variable device support Ralph . Lange
<2000>
<2000>
