1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: unbundled sequencer v1.9.5 is available
To: [email protected]
Date: Tue, 15 Feb 2000 14:37:23 -1000
X-Sun-Data-Type: text
X-Sun-Data-Description: text
X-Sun-Data-Name: text
X-Sun-Charset: us-ascii
X-Sun-Content-Lines: 21
Dear all,
I believe that I have fixed the "sequencer deletion via 'td'" problem in
the unbundled sequencer. I had introduced it a couple of years back (so
the problem that I have fixed is _not_ present in the EPICS base version
of the sequencer).
I have created a new v1.9.5 of the sequencer. Please refer to the following
URL for details on where to download it.
http://www2.keck.hawaii.edu:3636/realpublic/epics/seq
I would like to know of people who are using v1.9.4 and v1.9.5 operationally.
So far, I am only of aware of SLAC as users of v1.9.4.
William
PS, the change is very minor; I attach the source code diffs from v1.9.4.
X-Sun-Data-Type: default
X-Sun-Data-Name: diffs
X-Sun-Content-Lines: 51
Index: Version
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/seq/src/Version,v
retrieving revision 1.3
retrieving revision 1.4
diff -r1.3 -r1.4
1c1
< 1.9.4
> 1.9.5
Index: seqCom.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/seq/src/seqCom.h,v
retrieving revision 1.2
diff -r1.2 -r1.3
33c33
< #define	MAGIC	960811		/* current magic number for SPROG */
> #define	MAGIC	000215		/* current magic number for SPROG */
Index: seq_task.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/seq/src/seq_task.c,v
diff -r1.2 -r1.3
35a36
> 15feb00,wfl	Fixed problem (introduced by wfl) with sequencer deletion.
484,489c485
< 	/* Owing to persistent problems with ca_import() and ca_import_cancel(),
< 	   temporarily suppress them altogether (WFL, 13-Oct-97) */
< #if 0
< 	/* Cancel the CA context for each state set task (have to re-import
< 	   the context each time because ca_import_cancel() deletes the
< 	   ca_static task variable) */
> 	/* Cancel the CA context for each state set task */
492,493d487
< 		extern		int seqAuxTaskId;
498,503d491
< 		logMsg("   ca_import(0x%x)\n", seqAuxTaskId, 0,0,0,0,0);
< #endif	/*DEBUG_CLEANUP*/
< 		SEVCHK (ca_import(seqAuxTaskId),
< 			"seq_cleanup:ca_import() failed")
< #ifdef	DEBUG_CLEANUP
509d496
< #endif
Prev: Re: Improving S/N on tech-talk Maren Purves
Next: Re: IOC Errors when StripTool is Running Christopher A. Larrieu
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Improving S/N on tech-talk Christopher A. Larrieu
Next: Greenspring Octal serial IP question john sinclair
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
