1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: native type of gdd object
To: "Vladimir Sirotenko" <[email protected]>, <[email protected]>
Date: Wed, 23 Feb 2000 10:54:26 -0700
Vladimir,
> Could someone advise me please how to control the native type of PV created
> in portable CA server
> with use of  gdd library ( pVV =  new gddScalar(gddAppType_value,
> aitEnumFloat32); )
> I mean native type which can be asked using  ca_field_type() function ..
> I have two servers running with the same PV creation, but one gives native
> type = 2 (float) and
> another gives 0 (string). Is there any way to change native type from 0 to
> 2, for example? Thanks,
The virtual function "casPV::bestExternalType ()" determines the native data type
as seen by the client application. The base implementation of this virtual
function returns type string, but you can override this behavior by implementing a
replacement in your derived class.
Jeff
Re: native type of gdd object Vladimir Sirotenko
Prev: native type of gdd object Vladimir Sirotenko
Next: Re: native type of gdd object Kay Kasemir
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: native type of gdd object Vladimir Sirotenko
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
