>>>>> "Isabelle" == Pierre MATTEI <[email protected]> writes:
> I'm Isabelle YAO and I work for the CEA-Saclay.
> I use EPICS R3.13.0.beta11, with a SOLARIS workstation.
> I'm in charge of the design of a vacuum synoptic using MEDM
> 2.3.5a.
> I would like to know if vacuum objects, like pumps, gauges,
> valves, already exist.
> Another question : is it possible to upgrade the library of
> MEDM by creating new objects (like magnets, DCCT, or
> insertion devices like Faraday cup, profilers, ...) ?
I don't know if MEDM 2.3.5 is able to do what you want, but I'd like to
mention, that dm2k (the "european" version of MEDM, formerly named MEDM 2.4,
MEDM/DESY...) provides such a feature.
In dm2k, there is sth. called "Dynamic Symbol" which enables you to have a
library (i.e. another adl-file) of more or less complex groups of objects.
At runtime dm2k picks the object to display depending on the value of a PV,
so it may even change the displayed object at runtime.
Using this, you can easily compose a set of objects representing open or
closed valves, pumps... in a single adl-file and reuse these objects in any
adl-file you create.
To make sharing of these libraries easier, I'd volunteer to add an area to
the dm2k homepage to make those symbol-libraries available to others. Just
send me your adl-files and the corresponding part of the graphic rules.
The current version of dm2k is 2.5.1 and is available at
http://www-csr.bessy.de/control/SoftDist/dm2k/
2.5.2 is currently undergoing some final tests and will be released soon.
This version will then also support cdev instead of channel access (thanks
to J.Chen @ JLab)!
Thomas Birke
__________________________________________________________________________
/homas Birke [email protected]
Berliner Elektronenspeicherringesellschaft für Synchrotronstrahlung m.b.H.
BESSY Tel: +49 30 6392 4934
Albert Einstein Straße 15 Fax: +49 30 6392 4859
12489 Berlin
Germany
- MEDM widgets Pierre MATTEI
CA Server disconnects Paul Sichta
<2000>
Re: MEDM widgets Ken Evans
<2000>
