1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Status return from EPICS device support
From: "J. Frederick Bartlett ([email protected])" <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Thu, 25 May 2000 12:20:49 CDT
  I have a question for the experts. Is there a standard field in all
records in which detailed device status (status from device support)
may be placed where is is accessible by a database get operation.
  My particular difficulty appears with asynchronous device support
for the MIL/STD1553B bus. We have a controller for the 1553 bus which
generates an interrupt at the end of a bus transaction. The 1553 bus
driver reschedules record "processing" (PACT is non-zero at this point) at
interrupt time via a call to callbackRequestProcessCallback, passing a
longword with bus I/O completion status. I need to save this status in
a standard record field (one that all records have) so that, if there
was an error, the application program may retrieve it. Any
suggestions?
						Fritz Bartlett
RE: Status return from EPICS device support Jeff Hill
Prev: Re: archiver record Andrew Johnson
Next: Re: archiver record Albert
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: archiver record Albert
Next: RE: Status return from EPICS device support Jeff Hill
