1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Alarm for Analog Input
To: [email protected]
Cc: [email protected], [email protected]
Date: Wed, 07 Jun 2000 17:32:35 -0400
To Whom it May Concern,
	I am attempting to set an alarm condition for an analog
input EPICS record that monitors the status of our LeCroy 1458
mainframes that we use for HV modules here at BNL for the
PHENIX detector used in the RHIC accelerator.  What I want to
happen is that an alarm should go off when the mainframe is
powered off (which has happened mysteriously).
	When I edit the alarm configuration file to include
the record, I see <UDF,INVALID> displayed in the main alarm
window next to the record.  Unfortunately, when I power off
the mainframe, no alarm is activated.
	If I look at the record via a 'dbpr' command, I see
that the STAT field has a value of UDF.
	Any advice as to how I can implement this alarm?
	Thanks in advance.
	regards,
	Lars Ewell
______________________________________
 Lars Ewell
 Brookhaven National Laboratory
 PHENIX Group
 Physics Dept. 510C
 Upton, NY 11973
 [email protected]
 Phone (631)344-7070
 FAX   (631)344-3253
 www   http://boink.rhic.bnl.gov/~ewell
Prev: Re: timestampRecord release Marty Kraimer
Next: Problem with CA client in Linux Josep A. Perlas
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: FW: timestampRecord release Jeff Hill
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
