1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with CA client in Linux
To: "Josep A. Perlas" <[email protected]>
Cc: EPICS collaboration <[email protected]>
Date: Fri, 09 Jun 2000 12:17:53 +0000
Dear Josep,
     What version of EPICS are you running?
Pete Siddons.
"Josep A. Perlas" wrote:
> Dear all,
> We have been working with EPICS using Solaris and VxWorks for the
> last three years, and now we would like to test EPICS (CA client) in Linux.
> The Linux version that we have is Red Hat Linux release 6.1 with
> Kernel 2.2.12-20 running on a Pentium PC.
> We start the caRepeater by hand (as suggested in the README.Linux file),
> and it works, but when we run a Channel Access test program then it crashes.
> After an elementary debugging process (consisting in adding some "printf"s
> before an after a function call) we have seen that the error appears
> when "ca_task_initialize" is called. In particular, a "Segmentation fault"
> happens when the function "ca_os_indepen_init" just returns.
> I understand that this is not much information but any hint on this
> problem will be very welcome.
> Thanks in advance for your help.
>                        Josep
> _____________________________________________________
> Dr. Josep A. Perlas
> Lab. Llum Sincrotro - IFAE ------------  Tel: (+34 93)581.28.38
> Edifici Cn, Campus UAB     ------------   Fax: (+34 93)581.32.13
> E-08193 Bellaterra (Barcelona) SPAIN ---- email: [email protected]
Problem with CA client in Linux Josep A. Perlas
Prev: Problem with CA client in Linux Josep A. Perlas
Next: network config Pierre MATTEI
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
