At 02:57 PM 7/6/00 -0500, Vladimir Sirotenko wrote:
>Hi,
>I am building base EPICS (host) under KAI compiler KCC on Linux box
>and build was ok with several warnings.
>Unfortunately, CA client does not work.
>When I run ca_test (with excas running) I got the following:
><d0lxbld4> ca_test janet
>CAC: post_msg(): Corrupt cmd in UDP msg d00
Could it be that your compilation does not handle the byte swapping?
On Linux (PCs), the macros in Epics/base/src/ca/net_convert.h
that try to figure out whether you need byte swapping or not
depend on defines like
#elif defined(_M_IX86) || defined(_X86_)
Maybe these are defined per default for gcc/g++ but not your KAI?
-Kay
(not KAI)
- Building base EPICS 3.13.2 under KAI C++ compiler Vladimir Sirotenko
RE: Building base EPICS 3.13.2 under KAI C++ compiler Jeff Hill
<2000>
2025
<2000>
2025
