1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: How to build EPICS3.13.1 for PPC?
To: [email protected]
Date: Tue, 01 Aug 2000 16:46:03 +0800
Hello,
I use EPICS3.13.1, vxWorks5.3.1(PPC2303). My host is Sun/Solaris2.7,
target is MV2302 board(PPC603).
Now I want to build base for PPC, I have modified some files.
In CONFIG_SITE_ENV:
I set 'CROSS_COMPILER_TARGET_ARCHS=mv2303'
And I create the CONFIG.Vx.mv2303:
# $Id: CONFIG.Vx.mv2303,v 1.1 1998/06/04 19:15:13 wlupton Exp $
# This file is maintained by the EPICS community.
# Vx GNU cross compiler suffix
CMPLR_SUFFIX = ppc
# For Vx directories of form:
#   $(VX_DIR)/$(HOST_ARCH).$(ARCH_CLASS)/bin
ARCH_CLASS = ppc
# Architecture specific build flags (TRUE=1 via LBL; needed in
camessage.c)
ARCH_DEP_CFLAGS = -fno-for-scope -DCPU_FAMILY=PPC -DCPU=PPC603
-D_GNU_TOOL -DTRUE=1
But when I use gnumake in the epics/base/ , it gives the following
errors:
/ssrf/project/master/wind/T1.0.1/host/sun4-solaris2/bin/ccppc
-B/ssrf/project/master/wind/T1.0.1/host/sun4-solaris2/lib/gcc-lib/
-nostdinc -ansi
 -pedantic -O2 -fstrength-reduce  -Wall   -fno-for-scope
 -D_GNU_TOOL -DTRUE=1  -DvxWorks -DV5_vxWorks -fno-builtin  -I. -I..
-I../../../include -I../../../include/os/vxWorks
-I/ssrf/project/master/wind/T1.0.1/target/h   -c  ../iocinf.c
In file included from ../iocinf.h:212,
                 from ../iocinf.c:151:
../caProto.h:241: syntax error before `.'
../iocinf.c:146: warning: `sccsId' defined but not used
../os_depen.h:36: warning: `os_depenhSccsId' defined but not used
gmake[3]: *** [iocinf.o] Error 1
gmake[3]: Leaving directory
`/ssrf/project/master/epics/R3.13.1/base/src/ca/O.mv2303'
gmake[2]: *** [buildInstall.mv2303] Error 2
gmake[2]: Leaving directory
`/ssrf/project/master/epics/R3.13.1/base/src/ca'
gmake[1]: *** [ca.buildInstall] Error 2
gmake[1]: Leaving directory
`/ssrf/project/master/epics/R3.13.1/base/src'
gmake: *** [src.buildInstall] Error 2
How can I do?
Best Regards,
guobao shen
RE: How to build EPICS3.13.1 for PPC? Jeff Hill
Prev: RE: delphi interface to EPICS? Jeff Hill
Next: RE: How to build EPICS3.13.1 for PPC? Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
