1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RFC: Graphical Database Editor
To: EPICS tech-talk <[email protected]>
Date: Wed, 02 Aug 2000 14:00:26 -0500
This message is a Request for Comments and meant to start some discussion
on how we create and edit EPICS databases, an area in which I believe we
are lacking a major tool.  This proposal will not be appropriate for all
sites, but I believe that I have found a good starting point for
developing a suitable hierarchical graphical database editor.  I'm also
looking for anyone interested in collaborating with the necessary
development work.
TkGate (see http://www.cs.cmu.edu/~hansen/tkgate/ for screen shots &
source download) is a free [GPL] schematic capture program (and a circuit
simulator although that's of no use to us) which is written in a
combination of C and tcl/tk.  It supports hierarchical editing and
printing to PostScript, and internally seems nicely modular.  I think it
would be worth using this as the basis for developing a proper graphical
database editor.
NB: TkGate already includes support for Japanese as well as English; if
KEK or another Asian lab were to get involved we could aim to maintain
this in the db editor, and maybe add other languages too.
I can foresee questions/objections from some sites - tkGate doesn't run
under Windows (although most Unix flavours are supported) because it uses
X for drawing whereas AIUI Tk uses the windows GDI on that platform.  I
don't know how much work it would take to make it portable, but it will
probably help that we'll be stripping out a lot of graphics stuff from the
current tkGate code.  I have no interest in working on a Windows version
myself though.
Here is an initial list of jobs that will need doing; I've not gone into
the source in too much detail yet so this is only very preliminary:
  * Document what we're aiming to produce (requirements)
  * Analyse the existing code more closely to understand it
  * Remove the simulator and support for most schematic objects
  * Replace the verilog load/save format with dbStaticLib
  * Work out how to retain graphical layout data in dbStaticLib
  * Write a generic "record" schematic object
  * Modify the hierarchy object (module) to add macros
  * Overhaul the object Properties dialog & support
  * Create a crude auto-layout engine for existing .db files?
  * Modify wiring routines to handle INP/OUT links and fields
  * GUI changes
All comments welcome, both positive and negative.  If someone already has
a better proposal or source code to start from I think we should start
discussing it - IMHO we *need* a graphical editor that properly
understands databases, or EPICS will not survive and grow in the longer
term.
- Andrew
Sharks kill 10 people each year.  People kill 60,000,000 sharks each year.
Re: RFC: Graphical Database Editor bickley
Re: RFC: Graphical Database Editor Benjamin Franksen
Re: RFC: Graphical Database Editor Steve Lewis
Prev: RE: How to build EPICS3.13.1 for PPC? Jeff Hill
Next: Re: RFC: Graphical Database Editor bickley
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
