1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Download vxWorks to IOC
To: [email protected]
Date: Mon, 30 Oct 2000 15:51:43 -0600 (CST)
> At 09:12 AM 10/27/00 +0800, chengwx wrote:
> >Hello everyone,  I have make the epics base and medm. and make the epics
> >application on my Redhat6.2.
> >But when download the vxWorks, it comes the errors like this :
> >[VxWorks Boot]: @
> >Loading... 413736 + 43300 + 35280                 /* the ioc stopped
> >here, no moving  at all*/
> I had a similar problem when loading from RedHat 6.2.
> The problem was in wuftpd.
> In fact we use almost the same ftpd on solaris and there the problem
> didn't appear, so I don't understand it fully, but these were symptons
> and the solution:
I have run into this problem on Debian Linux too, but have come up with
a different solution, which is to use a different FTP daemon.  Debian
has installable packages for three different FTP daemons, namely, the
WU-ftpd, ProFTPD, and a port of the OpenBSD FTP daemon.  If you use
either the OpenBSD daemon or ProFTPD, the VME crate boots just fine.
However, if you use WU-ftpd, the boot of the VME crate becomes glacially
slow.  In fact, it is so slow that usually the VxWorks boot code times
out before the boot completes.  Thus, I would recommend that you try a
different FTP daemon and see if that works better.
Bill Lavender
[email protected]
Re: Download vxWorks to IOC Kay Kasemir
Prev: Re: Download vxWorks to IOC Kay Kasemir
Next: VxWorks login authentication Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Collaboration Meeting 1:00 pm November 13th through 1:00 pm November 16th Leo Dalesio
