Hi all!
I'm running EPICS on target shell.Whenever I try commands involving the
routine, "dbNameToAddr" they get failed.Like,dba,dbpr etc.,.In short I'm
not able to access any fields of the record.
-> dba("aiExample1.VAL")
Record Address: 0x2 Field Address: 0x2 Field Description: 0x3b4c178
No Elements: 62427488
Record Type:
data access
Exception current instruction address: 0x001347dc
Machine Status Register: 0x0000b030
Data Access Register: 0xbf3efbe7
Condition Register: 0x48400042
Data storage interrupt Register: 0x40000000
1b34ec vxTaskEntry +60 : shell ()
1a4e68 shell +18c: 1a4e94 ()
1a50b8 shell +3dc: execute ()
1a523c execute +d8 : yyparse ()
1d90c8 yyparse +7a8: 1d7010 ()
1d7188 yystart +8f8: dba ()
filename="../dbTest.c" line number=792
Record Not Found dbNameToAddr error
3a1b7fc dba +38 : 3a1de98 ()
3a1df6c dbhcr +270: 1a0930 ()
1a0930 fioFormatV +784: strlen ()
shell restarted.
->dbPvdDump(pdbbase,1)
Process Variable Directory
dbPvdHashTableSize 512 dbPvdHashTableShift 1
025=001 tornado:calcExample
047=001 tornado:aiExample3
093=001 tornado:aiExample
223=001 tornado:aiExample2
303=001 tornado:calcExample1
311=001 tornado:xxxExample
315=001 tornado:calcExample3
319=001 tornado:aiExample1
353=001 tornado:calcExample2
End of Process Variable Directory
value = 35 = 0x23 = '#'
dbDumpPath gives a message that path was not found.Is that any problemm
with dbentry or pdbbase?
dbnr,scanppl,dbDumpFldDes,dbDumpRecord etc., are working fine.
All suggestions are invited.Thanks in advance.
Mythili.S.
p.s: One more thing,Whenever I tried to create an 'example' application
using templates,I've to make the files under each subdirectory
individually,as the 'Makefile' which is supposed to get created in
<apptop> is not getting created.This is the content of <apptop>
app1app bin config db dbd include iosBoot javalib
stripTool Rolf Keitel
Delay of Maximize Severity in OUT Links Benjamin Franksen
<2000>
2025
2026
<2000>
2025
2026
