1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: interp and mbbi/o-direct
To: "Tech-Talk (E-mail)" <[email protected]>
Date: Fri, 15 Dec 2000 15:45:31 -0800
I am using EPICS R3.13.3.  The EPICS Record Reference Manual describes
"Multi-Bit Binary Input Direct" and "Multi-Bit Binary Output Direct", which
look like useful records to unbundle a set of bits from a two-byte word.  I
can see that these records are in the EPICS base (
/EPICS/R3.13.3/bin/mv2700/mbbiDirectRecord.o, etc.), but there are no
symbols for them in the CapFast library.  I fetched the library from the APS
site
(http://www.aps.anl.gov/xfd/SoftDist/Distribution/epics/extensions/UnbuiltTa
rfiles/extensions313_2/edif.tar.gz), but this appears to contain a very old
set of CapFast symbols:
bash:/epics/extensions/src/edif/lib>ls -l    (edited for length)
total 297
-rw-r--r--   1 redman   544         33773 Aug 19  1995 edb.def
-rw-r--r--   1 redman   544          3858 Aug 16  1995 epics.mnu
-rw-r--r--   1 redman   544        425984 Aug 19  1995 sym.tar
and, as expected, all the symbols in sym.tar date back to 1995 or earlier.
The same library seems to be present in the "Comprehensive tarfile of
extensions ext313_2.tar.gz released on 03/08/00". Is there a newer set of
CapFast symbols available that contains up-to-date symbols for all the
records in the R3.13 base?
In a related problem, I have attempted to fetch the "interp" record from the
link in the http://www.aps.anl.gov/epics/modules/soft.php site, which points
at ftp://ftp.keck.hawaii.edu/pub/wlupton/interp-2-12.tar.gz.  This link no
longer works.  The Keck EPICS web site at
http://pipeline.keck.hawaii.edu:3636/realpublic/epics/ does not even list
this record.  Is the interp record still supported?  Is it available
anywhere?
Cheers,
Russell O. Redman
Re: interp and mbbi/o-direct Andrew Johnson
Prev: base release 3.13.4 Marty Kraimer
Next: Re: Asking for help about iocInit Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: base release 3.13.4 Steven Hartman
Next: Re: interp and mbbi/o-direct Andrew Johnson
