1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: The memory map of mv2302
To: <[email protected]>
Date: Mon, 5 Mar 2001 14:53:13 +0800
Dear Sir:
     I have developed the TD4V card's EPICS driver successfully under the help of Tobiyama, TD4V card is a programmable delay module used in Timing system ( KEKB guys maybe familar with this card). The developing system was based on mv162+Redhat6.2(with EPICS).
     The card initing code of device support is like this:
if(sysBusToLocalAdrs(VME_AM_EXT_SUP_DATA,(char *)Base_IO,(char **)&p)==ERROR)
       logMsg("VmeTd4v: cannot find extended address space\n");
       return(ERROR);
}                                        /* The memory of 162 is correct*/
for(cardNum=0;cardNum<td4v_num_links;cardNum++)
    if(vxMemProbe((char *)&(p->PreSet),READ,2,&probeVal[0])<OK)
        logMsg("No TD$V with cardNum=%d\n probe=%x\n",cardNum,p);
        cards[cardNum].card=NULL;
    else
        logMsg("Found TD4V with cardNum=%d\n address=%x\n",cardNum,p);
        cards[cardNum].card=p;
Now I want to change the mv162 board to mv2302. using the same initing code. and set the proper Base_IO address under the instruction of .../target/config/mv2302/target.nr  This time it doesn't work at all.
What's wrong about the memory map of 2302 ?
Prev: Re: what is the problem about my medm? Ernest L. Williams Jr.
Next: Re: The memory map of mv2302 Timo Korhonen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
