1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: wait record, calcout record and 3.13.4
To: [email protected]
Cc: [email protected]
Date: Thu, 19 Apr 2001 08:22:57 -0500 (CDT)
> Dear All,
> Does the "wait" record work under 3.13.4?
> I noticed that the support for this is included in the distrubution
> but is commented out of the default "base.dbd" and "baseLIBOBJS".
Andy,
I don't know about 3.13.4, but it looks like it disappears altogether (in base)
in 3.14.0alpha2. I would strongly recommend converting wait records to
calcout records. The wait record was developed before "dynamic link fields"
existed so it uses different field types (strings) to specify input links
and it has its own library of CA routines (recDynLink). All this should be
left behind and the calcout record should be used (which implements things
using standard system software).
	Ned
> I uncommented it in my build but I'm getting some unexpected
> results from using it.
> Is the "calcout" record a replacement for the "wait" record in 3.13?
> If so, then I expect moving an application from 3.12->3.13
> will mean I either have to replace all instances of "wait" with a
> "calcout" or take a closer look at why the "wait" isn't doing as
> I expect. Can anyone comment on similiar problems?
> Does anyone have a Capfast symbol for the "calcout" record?
> Thanks in advance for your help,
> Cheers,
> Andy
> Observatory Sciences Limited		Email: [email protected]
> William James House			Tel:  44 - (0)1223 - 508257
> Cowley Road			Fax: 44 - (0)1223 - 508258
> Cambridge, CB4 0WX, UK		http://www.observatorysciences.co.uk
Prev: wait record, calcout record and 3.13.4 Andy Foster
Next: Re: wait record, calcout record and 3.13.4 Pam Gurd
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: wait record, calcout record and 3.13.4 Pam Gurd
Next: iseg high voltage supply Porter, Rodney
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
