1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: medm & x-term color table
To: "Mark Rivers" <[email protected]>, <[email protected]>
Date: Fri, 20 Apr 2001 11:57:00 -0400
Mark.
Thanks, but.. Been there, done that.
The IDL color-limit works fine.  Netscape 4.x supports color limiting via
the -ncols switch,  but netscape 6 and MS iexplorer do not.  We have an
'asp' application (memo class) that will not run under netscape 4.77 on our
Ultra30 creator3D workstation, with Solaris 8.    So,  the primary culprit
at this is the web browser and we're stuck with the color-gobbler type.
Is there a 'harder' way that you know of to lock-in specified RGB values?
-ps
----- Original Message -----
To: "'Paul Sichta '" <[email protected]>
Sent: Friday, April 20, 2001 11:10 AM
Subject: RE: medm & x-term color table
> Paul,
> I think the easiest solution to this problem is to restrict IDL and
netscape
> to use fewer colors. For IDL put the line
> idl.colors: 32
> for example in your .Xdefaults file.
> For netscape there is a similar setting or command line switch, though I
> forget what it is.
> Mark
Prev: medm & x-term color table Paul Sichta
Next: Re: medm & x-term color table Ken Evans
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
