At 1:56 PM -0500 2001/04/25, Tim Mooney wrote:
>The most irritating bug in gdct for us has been its tendency to replace
>record_name.<field_name> with record_name.VAL in links. (The graphical
>link continues to point to the correct field, but the .db file doesn't
>agree.) I have never determined the circumstances under which this
>occurs, because the replacement in not apparent until you try to run
>the .db file. Have you guys run into this problem?
Yes, I have seen it; and I also cannot pin down the precise
circumstances that trigger it.
Also note that deleting a record sometimes visibly deletes but it still
exists in the .db; a "Hidden Record delete" is required; again, not
clear exactly what is the context.
The never-functional "Print" command disappeared with the R13 edition;
so did the very handy ability to import a straight .db and promote
it to graphical state (although you can still import and edit Hidden).
For those of you who have not tried GDCT in a long while, two features
were added over a year ago:
-can remove as well as add exposed fields
-can edit annotation text (had to delete/re-add before). With the
fix in the text-edit due to ivtools, this is more useful.
OK, JDCT folks: your turn to upgrade!
_____________________________________________________________________
Stephen A. Lewis | [email protected]
Mail Stop 71-259 | http://www.lbl.gov/~salewis
Lawrence Berkeley National Laboratory | Tel: +1.510.486.7702
Berkeley, CA 94720 USA | FAX: +1.510.486.4544
- Re: gdct built with ivtools Tim Mooney
Re: gdct built with ivtools - bug Kristi Luchini
<2001>
<2001>
