1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Input records with no device support
From: "J. Frederick Bartlett ([email protected])" <[email protected]>
To: [email protected]
Date: Fri, 08 Jun 2001 14:21:27 CDT
  After diligently searching the "Application Developer's Guide", the
"Record Reference Manual", and the EPICS tutorials, I cannot find the
answer to this question or an example that would answer it.
  I wish to instantiate an input record (say, ai) that has no device
support. I plan to set the VAL field from a process on the IOC using a
runtime database access routine (dbPutField) and force the record to
process -- and thereby trigger a change-of-value monitor -- by calling
dbProcess. The question is: what do I put in the DTYP and INPUT fields
of the record when I define it in a .db file?
  There are examples of an ai record that serves as an input to one
of the calc record's input values, but all of these are CAPFAST
diagrams that do not show the values in these two fields.
							Fritz
Re: Input records with no device support Steven Hartman
Re: Input records with no device support Marty Kraimer
Prev: vxworks bsps john sinclair
Next: Re: Input records with no device support Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
