1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Another possible problem in e2db
To: "Tech-Talk (E-mail)" <[email protected]>
Date: Wed, 13 Jun 2001 10:44:12 -0700
I have located what may be a second problem in e2db, also related to
uninitialised pointers.  This one is triggered by leaving states unmodified
in mbbi and mbbo records.  For example, I have a record "conb:RTS:inSignals"
which defines the first four states ZRST="NSC_NDV", ONST="SC_NDV",
TWST="NSC_DV", and THST="SC_DV", but not any of the higher states.  In the
edif file this becomes
          (instance (rename inSignals "inSignals")
            (viewRef NETLIST_VIEW
              (cellRef embbisim))
            (property (rename ZRVL "ZRVL")
              (string "0"))
            (property (rename ZRST "ZRST")
              (string "NSC_NDV"))
            (property (rename TWVL "TWVL")
              (string "2"))
            (property (rename TWST "TWST")
              (string "NSC_DV"))
            (property (rename THVL "THVL")
              (string "3"))
            (property (rename THST "THST")
              (string "SC_DV"))
            (property (rename ONVL "ONVL")
              (string "1"))
            (property (rename ONST "ONST")
              (string "SC_NDV")))
The cellRef to "embbisim" provides default definitions for the other
properties:
    (cell (rename embbisim "embbisim")
      (cellType GENERIC)
      (view NETLIST_VIEW (viewType NETLIST)
        (interface
... skipping the ports and most of the other properties ...
          (property (rename FVST "FVST")
            (string ""))
          (property (rename FTVL "FTVL")
            (string "0"))
          (property (rename FTSV "FTSV")
            (string "NO_ALARM"))
          (property (rename FTST "FTST")
            (string ""))
          (property (rename FRVL "FRVL")
            (string "0"))
          (property (rename FRSV "FRSV")
          (property (rename FRST "FRST")
            (string ""))
It will be noted that FRST, FVST, etc are correctly assigned default values
In the final .db file, however, we find
record(mbbi,"conb:RTS:inSignals") {
    field(DESC,"multibit binary input rec")
    field(SCAN,"Passive")
    field(PINI,"NO")
    field(PHAS,"0")
    field(EVNT,"0")
    field(DTYP,"Soft Channel")
    field(DISV,"1")
    field(SDIS,"0.000000000000000e+00")
    field(DISS,"NO_ALARM")
    field(PRIO,"LOW")
    field(FLNK,"0.000000000000000e+00")
    field(NOBT,"0")
    field(INP,"0.000000000000000e+00")
    field(ZRVL,"0")
    field(ONVL,"1")
    field(TWVL,"2")
    field(THVL,"3")
    field(FRVL,"0")
... skipping FVVL, etc ...
   field(ZRST,"NSC_NDV")
    field(ONST,"SC_NDV")
    field(TWST,"NSC_DV")
    field(THST,"SC_DV")
field(FRST,"<CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD>
<CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD><CD>
<CD>
<CD>
<CD>
<CD><CD><CD><CD><FD><FD><FD><FD><D1>")
and FVST, SXST, etc are all bit-wise identical to FRST.  These values should
still be "".  The database causes dbLoadRecords to freeze.  My
investigations over the last week has sensitized me to the likelihood that
the repeated bit pattern <CD> is a probably indicator of an uninitialized
pointer.
Checking through edifRead, we find that properties are represented by
	struct prop {
	        struct prop *flink;             /* link to next prop */
	        char name[NL];                  /* property name */
	        char val[NL];                   /* property value string */
which are malloced from the heap.  The prop.name and prop.val fields are not
initialized, and represent 80 characters (NL=80) of random memory.  From the
edif fragment, these fields are read as strings in the procedures readprop
in edifRead.c.  The relevant fragment is
			case STRING:
				getval(file, 0);
				if (sscanf(edif_temp, "%s", junk) == -1)
					readstring(file, level);
				else
					strncpy(curprop->val, edif_temp,
NL);
				break;
where "edif_temp" has been filled with the value of the string, "" in this
case which means edif_temp[0]==EOS.  The sscanf will fail to read a string
and will return -1, so that readstring is invoked to fill in the field.
However, readstring looks for a key STRINGDISPLAY, which does not exist, and
therefore does nothing.  The result is that nothing is ever assigned to the
prop.val string.  A solution is to initialise curprop->val to "" before
calling readstring.  Note that this is harmless if readstring actually finds
a value.  Thus the modified code for readprop becomes
			case STRING:
				getval(file, 0);
					  /* initialise curprop->val in case
readstring does not
					     find anything either, R. O.
Redman 2001-06-13 */
					  strcpy(curprop->val,"");
				else
NL);
				break;
With this change, the database is now generated correctly:
    field(PINI,"NO")
    field(PHAS,"0")
    field(EVNT,"0")
    field(DISV,"1")
    field(PRIO,"LOW")
    field(NOBT,"0")
    field(ZRVL,"0")
    field(ONVL,"1")
    field(TWVL,"2")
    field(THVL,"3")
    field(FRVL,"0")
    field(THST,"SC_DV")
    field(FRST,"")
    field(FVST,"")
    field(SXST,"")
I have attached my modified version of edifRead.c.  This file now has two
changes from the original.  Look for "Redman" to find them.
Cheers,
Russell O. Redman
Attachment: edifRead.c
Description: Binary data
Prev: OSF bug Geoff Savage
Next: Re: Bug in e2db Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Bug in e2db and "FATAL error" Rozelle Wright
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
