1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Which EPICS Makefile variable should I use?
From: "J. Frederick Bartlett ([email protected])" <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Tue, 31 Jul 2001 13:16:28 CDT
  I am building some IOC applications that make use of object files
obtained from other, non-EPICS libraries. These libraries are included
in the linker search list by adding them to the Makefile variable
USR_LDLIBS in Makefile.Vx. The use of this variable, incidentally,
does not appear to be documented in "EPICS IOC Software Configuration
Manual". I do not remember how I discovered its existence; however, I
suspect that I perused the collection of EPICS Makefile rules.
  What I now need to do is specify some directories that will be
searched to obtain some object files that are not in libraries. Is
there a Makefile variable to which I might add this list of
directories?
						Fritz
Prev: RE: [Fwd: socket errors] Jeff Hill
Next: Re: Error Message Zoltan Kakucs
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: VMIC 4145 Support Garrett D. Rinehart
Next: ca assert Vladimir Sirotenko
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
