1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: mbbiDirect/mbboDirect - why only 16 bits ?
To: [email protected]
Cc: [email protected]
Date: Fri, 24 Aug 2001 12:41:41 -0400
Why do the mbbiDirect and mbboDirect records only support 16 bits ?
Why is RVAL defined as SPC_NOMOD in mbboDirectRecord.dbd (making it
impossible to work around that limitation) while the Record Ref Manual
states that RVAL is Access=YES, Modify=YES ?
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: mbbiDirect/mbboDirect - why only 16 bits ? Brian McAllister
Prev: Re: devNode, drvNode, drvSerial source? Peregrine M. McGehee
Next: Problem talking CA across two CPUs in same crate??? Leonard J. Reder
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: mbbiDirect/mbboDirect - why only 16 bits ? Brian McAllister
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
