1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Problem talking CA across two CPUs in same crate???
To: "'Jeff Hill'" <[email protected]>, Mark Rivers <[email protected]>
Cc: EPICS-tech-talk <[email protected]>
Date: Fri, 24 Aug 2001 18:37:51 -0500
> -----Original Message-----
> From: Jeff Hill [mailto:[email protected]]
> Sent: Friday, August 24, 2001 6:14 PM
> To: [email protected]
> Cc: EPICS-tech-talk
> Perhaps you have the "gateway IP" set in the vxWorks boot
> parameters. This results in an odd route auto-configured by WRS
> that sends all IP packets to the router even if the destination
> is on the attached LAN. This can be fixed by using the routeDelete
> command followed by the routeAdd command.
Another problem could be that a backplane IP address was set with the
incorrect subnet mask.  We had this problem.  The "correct" subnet mask for
the backplane is 0xFFFFFFFF, i.e. all 1's.  Not setting a subnet mask for
the backplane IP address will result in the default of 0XFFFF0000, and the
backplane becomes your default route to the world, and it's a dead-end. If
you are not using the backplane network then just delete the backplane IP
address.
Mark Rivers
Re: Problem talking CA across two CPUs in same crate??? Andrew Johnson
Prev: RE: Problem talking CA across two CPUs in same crate??? Jeff Hill
Next: Re: Problem talking CA across two CPUs in same crate??? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Problem talking CA across two CPUs in same crate??? Leonard J. Reder
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
