1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: alarm handler confusion (and solution)
To: Maren Purves <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 28 Aug 2001 10:49:55 +0200
  > It appears that the cut-off in the addressing is not in the mail
  > forwarding but in the alarm handler reading its configuration file.
  > What is the limit on the line length in alarm handler config files?
Oops,
the config file line length is limited by a buffer which is of length
MAX_STRING_LENGTH, i.e. 500 (defined in alh.h).
It never appeared to me that this might be too short, but it obviously
is.
If I understand correctly, the ... exceptional length of your config
file lines is due to listing multiple mail addresses. Even without
having detailed knowledge about your mail forwarding scheme ... I would
always try to have alh call a (shell or perl) script instead of
populating the alh config file with email addresses. This not only keeps
config file lines short, it also nicely separates things: you don't have
to restart the alh (with all the additional log entries and stuff) just
because you changed the mail address lists. Also, a script could do
additional checking, e.g. don't send mails if a file called _SHUTDOWN_
exists - we use such a mechanism to keep things quiet in shutdown
periods with zillions of bogus alarms.
Cheers,
Ralph
Re: alarm handler confusion (and solution) Maren Purves
Prev: alarm handler confusion (and solution) Maren Purves
Next: Image capture Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: alarm handler confusion (and solution) Maren Purves
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
