1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Image capture
To: "Brian Tieman" <[email protected]>
Cc: "Rolf Keitel" <[email protected]>, "EPICS-tech-talk" <[email protected]>
Date: Tue, 28 Aug 2001 13:08:53 -0600
> If R3.14 does indeed address this limit for the PCAS it would be much simpler
> to move images over CA.
SNS requirements were that the array size limits be removed first from the client
library and the original server in iocCore (rsrv). SNS will also require that the
array size limits be removed from PCAS, but this has not been done yet.
Jeff
Re: Image capture Brian Tieman
Prev: Re: Image capture Peregrine M. McGehee
Next: Re: portable ca server john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Image capture Brian Tieman
Next: Re: Image capture Noboru Yamamoto
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
