1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: IOSCANPVT
To: Jim Thomas <[email protected]>
Cc: [email protected]
Date: Wed, 19 Sep 2001 07:39:28 -0500
Jim Thomas wrote:
> It appears to me that I would want one IOSCANPVT for each input bit.  That
> way only the records referencing that bit would get processed when that bit
> changes.  If I have a hundred records looking at one bit on the card and
> one record looking at another bit that changes much more often, aren't
> those hundred records processed needlessly?
> Or does mbbi handling require a common IOSCANPVT ?
> Mahalo,
> Jim
If you provide mbbi device support then you almost have to provide one IOSCANPVT
for each digital I/O word rather than each bit. Only the mask fields in each
record instance determines which bits are used by that record.
Marty Kraimer
IOSCANPVT Jim Thomas
Prev: Re: IOSCANPVT Bob Dalesio
Next: EPICS base release R3.13.5 Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
