1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: An et_wish crash
To: Epics Questions <[email protected]>
Date: Mon, 29 Oct 2001 18:14:24 +0000 (GMT)
Recently, while trying some examples with et_wish
at Daresbury Lab, it was noticed that it is possible
to cause a crash by monitoring the VAL field
of an "mbbi" record which is using "Raw Soft Channel"
device support.
The crash occurs if RVAL is set to a value which does
not correspond to a valid state.
Looking at "tclCa.c", the relevant code appears to be at
line 983:
  case DBF_ENUM:
    if (strlen(pch->info.e.strs[pch->pdata->e.value]) != 0) {
      Tcl_SetVar(pch->interp, pch->pitem->tclname,
                 pch->info.e.strs[pch->pdata->e.value],
                 TCL_GLOBAL_ONLY);
    } else {
      sprintf(buf, "%d", pch->pdata->e.value);
      Tcl_SetVar(pch->interp, pch->pitem->tclname, buf,
                 TCL_GLOBAL_ONLY);
    break;
The crash is caused by the "pch->info.e.strs[pch->pdata->e.value]"
because the index into the strs is out of range.
One solution would be to replace this with:
    if( pch->pdata->e.value <= pch->info.e.no_str )
                 TCL_GLOBAL_ONLY);
    else
                 TCL_GLOBAL_ONLY);
    break;
So that we only use a valid index into the array of state strings
otherwise we just report the value as given.
Cheers,
Andy
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
Re: An et_wish crash EPICS User
Prev: Re: Ladder logic programing for PLC Marty Kraimer
Next: Using a terminal server to catch boot messages bickley
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: An et_wish crash EPICS User
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
