1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VXI driver support
To: Jeff Hill <[email protected]>
Cc: "'John Faucett'" <[email protected]>, EPICS-tech-talk <[email protected]>
Date: Mon, 07 Jan 2002 16:57:07 -0600
Could there be a problem with using logical address 1?  ISTR that LA's map
directly to interrupt vector numbers, and most processors tend to reserve
the lower numbered interrupt vectors for other things (I don't know what
CPU is used in an hkbaja60 though).  Try switching to a logical address
above 0x40
I'm not sure whether that would explain these symptoms or not though, it
might just mean that you couldn't connect an interrupt routine to that
card, or it may be that it's only the MXI modules that have that
restriction.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
RE: VXI driver support Jeff Hill
Re: VXI driver support John Faucett
Prev: RE: VXI driver support Jeff Hill
Next: RE: VXI driver support Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
