1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ECA_BADTYPE
To: Geoff Savage <[email protected]>
Cc: [email protected]
Date: Wed, 20 Mar 2002 13:42:50 -0500 (EST)
On Wed, 20 Mar 2002, Geoff Savage wrote:
> We moved a computer in our control room yesterday and the CA clients are
> returning a status of ECA_BADTYPE for some of the reads.  The record
> being read is one unique to our hardware.  The field is of type
> DBR_LONG.  The switch reports errors on the port to which the host is
> connected.  These errors are Align-Err and FCS-Err.
FCS-err is a frame check sequence error, i.e. failed checksum for that
ethernet packet. Such packets are discarded by the device receiving them.
An FCS error suggests a bad ethernet cable / connection or too long of
cable. However the alignment error suggests a speed mismatch.
Since your errors appeared after a computer move, I would check that port
and cable for problems. There is also the possibility that the machine is
now attached to a different type of switch then previously which could
explain a speed mismatch. If so, configure the port on that switch with
the appropriate speed and duplex settings rather than letting it
autonegotiate and see if your problems go away.
Steve Hartman
[email protected] | 919-660-2650
Duke Free Electron Laser Laboratory
ECA_BADTYPE Geoff Savage
Prev: dbf_text vs. dbr_text Geoff Savage
Next: RE: ECA_BADTYPE Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ECA_BADTYPE Geoff Savage
