1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: calc/calcout and NAN
To: Marty Kraimer <[email protected]>
Cc: [email protected]
Date: Thu, 28 Mar 2002 17:29:34 +0100
Hi Marty,
there was a little bit more to this story:
I wanted to use the IVOA field in calcout record to prevent the
NAN to be propagated to further records when the return value
from the calculation is invalid. This almost works - but the
first time the 'nan' gets through and corrupts other records
down the chain. It can even hang the ioc, and what was particularly
nasty that the nan was propagated down to a motor record and the
controller card (oms58) 'died', i.e., needed a sysreset to restart
it (after ctl-x, iocInit was hanging.)
After some more investigation (by the way, 3.14 on a Linux host is a
tremendous tool to debug this kind of things!) I could figure out that
the value really got only out once. The record decides if the outputs
are driven by looking at sevr field. However, sevr is the alarm status
from previous processing and gets updated only when recGblResetAlarms
is called (which in this case is done in the monitor routine.)
Now, my question is: is it OK to check nsev instead of sevr here?
I don't see a reason why not, but I may be missing something.
The code (around line 588 in calcoutRecord.c, in routine execOutput):
       /* Check to see what to do if INVALID */
        if (pcalc->sevr < INVALID_ALARM ) {
            /* Output the value */
in the middle line, change pcalc->sevr to pcalc->nsev
This prevents the NAN being propagated (when the record is
configured properly.)
Timo
Timo Korhonen PSI (Paul Scherrer Institut), SLS
CH-5232 Villigen PSI
tel + 41- 56 3103262 fax + 41 - 56 310 3151
e-mail: [email protected]
Re: calc/calcout and NAN Marty Kraimer
calc/calcout and NAN Korhonen Timo
Re: calc/calcout and NAN Korhonen Timo
Prev: Re: calc/calcout and NAN Korhonen Timo
Next: Re: calc/calcout and NAN Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
