1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: AO Record: New Drive Limit Mode?
To: Kay-Uwe Kasemir <[email protected]>
Cc: [email protected]
Date: Tue, 09 Apr 2002 14:11:37 -0500
Kay-Uwe Kasemir wrote:
> At 10:20 AM 4/9/2002, Andrew Johnson wrote:
> >Doesn't the AO record already have a very similar behaviour controlled by
> >the IVOA field?  It's not quite the same, but do we really need this kind
> >of thing to be implemented twice?
> IVOA happens after the clamping, it doesn't solve the problem.
If you move the DRVH and DRVL values to HIHI and LOLO instead, set HHSV
and LLSV to INVALID_ALARM and IVOA to "Don't drive" then you should get
"reject" behaviour as far as the hardware is concerned - no value outside
of the limits ever gets sent out.  However you also get the record in an
INVALID_ALARM state, which might not be quite what you want so it's not
quite the same, and you do use up a pair of alarm limits, but you don't
have to modify aoRecord.c at all to get this behaviour.
I wonder if that's an indication that the clamping is happening at the
wrong point in the processing chain, or could the IVOA field be used to
control the drive limit mode instead of adding DRLM?  Would someone ever
want both at once?  I guess that's possible, but the two concepts seem to
be pretty closely related, as they're both associated with data validation
and what to do if you get bad data.
BTW, I'm just throwing out ideas here to ensure that we think this through
properly, not violently objecting to DRLM as such.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
Re: AO Record: New Drive Limit Mode? Korhonen Timo
AO Record: New Drive Limit Mode? Kay-Uwe Kasemir
Re: AO Record: New Drive Limit Mode? Kay-Uwe Kasemir
Prev: Re: AO Record: New Drive Limit Mode? Jim Thomas
Next: RE: ca_test bus error on solaris-sparc-gnu + fix Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: AO Record: New Drive Limit Mode? Kay-Uwe Kasemir
Next: Re: AO Record: New Drive Limit Mode? Korhonen Timo
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
