1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: NAN and INF
To: "'Marty Kraimer'" <[email protected]>, <[email protected]>
Date: Wed, 10 Apr 2002 10:19:52 -0600
Marty,
I suggest that you create an operating system independent interface and
then implement it in each of the OS specific directories under
src/include/os in R3.13. I suspect that you have already made similar
changes in R3.14?
Jeff
> -----Original Message-----
> From: Marty Kraimer [mailto:[email protected]]
> Sent: Wednesday, April 10, 2002 9:55 AM
> To: [email protected]
> Subject: NAN and INF
> Recently Timo Korhonen mentioned a problem caused by the calcoutRecord
> passing
> on a NaN value to other records. Recently we saw something that we
> suspect was
> caused by something generating either a NAN or an INF. The latest 3.13
> known
> problems describes a fix for the calcOutRecord (and calcPerform) that
> fixes the
> NAN problem. We are still not handling the INF problem.
> Let me first give a brief discussion of NAN and INF. The IEEE floating
> point
> standard defines the concept of NAN (not a number) and INF (infinity).
> For each
> the exponent portion of the number has a unique bit pattern (normally
> all 1s), A
> NAN has a nonzero significand and an INF has a zero significand. A NAN
> is
> generated for invalid operations like 0/0. An INF is generated for
> exponent
> overflow.
> Part of the solution to the NAN problem Timo discovered was to make
the
> following change to calcPerform
> diff -r1.31.6.1 calcPerform.c
> 104a105,106
>  > #include        <private/mathP.h> /* For isNan*/
>  > #define isnan isNan
> 517c519
> < return(0);
>  > return((isnan(*presult) ? -1 : 0));
> Thus a error is returned in calcPerform calculates a NAN. It looks
like
> a
> solution for both NAN and INF is to change the return to
> return(((isnan(*presult)||isinf(*presult)) ? -1 : 0));
> PROBLEM:
> This assumes that isnan and isinf are provided on all platforms that
> epics supports.
> Both isnan and isinf are defined as part of the ISO C standard from
1999.
> They are supported on redhat 7.2 linux. They are not supported on
> vxWorks 5.4 or
> on solaris 8. Not suprising considering the 1999 date.
> The following are diffs that allow me to compile 3.13 calcPerform on
> solaris,
> vxWorks, and linux redhat 7.2
>  > #include        <stddef.h>
> 119a115,128
>  > #ifdef vxWorks
>  > #include <vxWorks.h>
>  > #define isnan isNan
>  > #define isinf isInf
>  > #endif
>  > #ifdef SOLARIS
>  > #define __EXTENSIONS__
>  > #include <limits.h>
>  > #define isinf(D) \
>  > ((fabs((D))>DBL_MAX || fabs((D))<DBL_MIN) ? 1 : 0)
>  > #endif
> 519c528
> <       return(0);
> This is REALLY ugly. Worse what about HPUX, WINxx, and earlier
releases
> of
> Solaris and Linux?
> What to do??????
> Marty Kraimer
Re: NAN and INF Marty Kraimer
Prev: NAN and INF Marty Kraimer
Next: Re: NAN and INF Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
