1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Capturing a telnet connection event
To: [email protected]
Cc: [email protected]
Date: Thu, 11 Apr 2002 12:54:55 -0500
When a telnet session is initiated on a VxWorks IOC, there is some output on the console. You can capture this output by monitoring the console port over serial connection.
Here is an example  of that output (the time stamp was
added by my serial port monitoring process):
2001-10-25,16:21:47: telnetd: This system *IN USE* via telnet.
2001-10-25,16:21:47: shell restarted.
Pete Jemian
UNICAT
At 11:25 AM 11-04-02 -0500, you wrote:
  I have a situation in which I would like to know if someone has
created a telnet connection to an EPICS IOC.  I had hoped that the IOC
error logging facility might capture a telnet connection event;
however, it does not.  Has anyone else encountered this problem and is
there a solution?
Fritz
Capturing a telnet connection event J. Frederick Bartlett ([email protected])
Prev: Capturing a telnet connection event J. Frederick Bartlett ([email protected])
Next: Re: Capturing a telnet connection event Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Capturing a telnet connection event Andrew Johnson
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
