1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Capturing a telnet connection event
To: Kay-Uwe Kasemir <[email protected]>
Cc: [email protected]
Date: Thu, 11 Apr 2002 13:26:03 -0500
Kay-Uwe Kasemir wrote:
> At 12:16 PM 4/11/2002, Andrew Johnson wrote:
> >I use that here at APS to output the long DOE "you must be
> >authorized to use this machine" message before prompting for the username
> >and password.
> A documented alternative to that might be:
> loginStringSet("login (you must be authorized to use this machine): ")
.. which is fine if your message is short, but doesn't work if it's more
than a line or so (I forget the limit, but it's too small for DoE).  I
omitted this definition from my example (yuck):
static const char* doe_msg = "\t\t\tNOTICE TO USERS\n\n"
    "This is a Federal computer system and is the property of the
United\n"
    "States Government.  It is for authorized use only.  Users
(authorized\n"
    "or unauthorized) have no explicit or implicit expectation of
privacy.\n"
    "Any or all uses of this system and all files on this system may be\n"
    "intercepted, monitored, recorded, copied, audited, inspected, and\n"
    "disclosed to authorized site, Department of Energy, and law
enforcement\n"
    "personnel, as well as authorized officials of other agencies, both\n"
    "domestic and foreign.  By using this system, the user consents to
such\n"
    "interception, monitoring, recording, copying, auditing, inspection,
and\n"
    "disclosure at the discretion of authorized site or Department of
Energy\n"
    "personnel.  Unauthorized or improper use of this system may result
in\n"
    "administrative disciplinary action and civil and criminal penalties.
By\n"
    "continuing to use this system you indicate your awareness of and
consent\n"
    "to these terms and conditions of use.  LOG OFF IMMEDIATELY if you
do\n"
    "not agree to the conditions stated in this warning.";
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
Capturing a telnet connection event J. Frederick Bartlett ([email protected])
Re: Capturing a telnet connection event Kay-Uwe Kasemir
Prev: Re: Capturing a telnet connection event Kay-Uwe Kasemir
Next: Sequencer priority parameter Frank Lenkszus
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Capturing a telnet connection event Ned Arnold
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
