1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to handle EPICS monitors?
Cc: [email protected]
Date: Mon, 22 Apr 2002 07:56:12 -0500
Geoff Savage wrote:
> Jeff,
> Where is the address assigned to the monitor subscription data structures?
> I saw what you are disscussing in db_post_events() but I couldn't determine
> where the address is stored when the monitor is registered.
> Geoff
J. Frederick Bartlett ([email protected]) wrote:
To my considerable surprise, I found that the CA client received
monitor events for the STATUS field but not for the VAL field.
  So, how should I handle the monitoring of a VAL (or any other) field
that has the SPC_DBADDR property?
Fritz
This info is in the Application Developers Guide. In the 3.14.0beta1 version it is section 11.5.7 and 11.5.8.
A brief summary is.
When a CA client connects to a field of a record.
1) A DBADDR structure is allocated.
2) dbNameToAddr is called. It assigns values to the members of DBADDR.
3) If the fields has been declared SPC_DBADDR then the record support routine cvt_dbaddr is called. It is allowed to change any of the following members of DBADDR: no_elements, field_type, field_size, special, pfield, and dbr_type.
For example the waveformRecord cvt_dbaddr is
static long cvt_dbaddr(paddr)
    struct dbAddr *paddr;
    struct waveformRecord *pwf=(struct waveformRecord *)paddr->precord;
    paddr->pfield = (void *)(pwf->bptr);
    paddr->no_elements = pwf->nelm;
    paddr->field_type = pwf->ftvl;
    if(pwf->ftvl==0)  paddr->field_size = MAX_STRING_SIZE;
    else paddr->field_size = sizeofTypes[pwf->ftvl];
    paddr->dbr_field_type = pwf->ftvl;
    return(0);
Since it set pfield = bptr it calls
db_post_events(pwf,pwf->bptr,monitor_mask);
rather than
db_post_events(pwf,pwf->val,monitor_mask);
Note that section 11.5.8 says that the record support routine "get_array_info" is also allowed to change pfield. This allows record support to implement double buffering.
I hope this helps.
Marty Kraimer
How to handle EPICS monitors? J. Frederick Bartlett ([email protected])
Prev: Re: How to handle EPICS monitors? Geoff Savage
Next: Re: NAN and INF Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Licensing Andrew Johnson
