1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: 3.14 questions
To: Epics Tech-Talk <[email protected]>
Cc: Larry Doolittle <[email protected]>
Date: Fri, 26 Apr 2002 12:43:51 -0700
We've used 3.14.0beta1 to build an XCas-based CA server to run on linux
on a StrongARM chip here at the SNS Front-end project and I would like
to make some comments
1.  The make system to support cross-compilation of all EPICS parts
works very well.   This is a great improvement over the old build system
and is why we used 3.14 to build the server.
2.  ca and cas seem reliable.   Although it is termed a beta release, we
have no trouble to report with the functionality of these components,
even though there seems to be a lot on new code here.  Note that we have
not tested large arrays here at the front end.  One minor modification
to XCas code was necessary due to a slight change in the cas api.
3.  The size of many of the libraries (libCom and libCa are good
examples.) seems to have increased substantially.  iocCoreLib.munch
looks to be almost twice the size of 3.13.5 iocCore.  I'm sure I've
missed some discussions of the merits of having ever-increasing amounts
of C++ in EPICS base-- what are the perceived trade-offs here?
    Carl
// Carl Lionberger                              [email protected]
// Computer Systems Engineer                    Voice   (510) 486-7503
// Engineering Division                         Fax     (510) 486-4544
//              Berkeley National Laboratory    (LBNL)
RE: 3.14 questions Jeff Hill
Prev: Re: AO: Drive Limit Mode Andreas Luedeke
Next: [no subject] Xuedong Chai
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Racal 3161 Waveform Generator John Faucett
Next: RE: 3.14 questions Jeff Hill
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
