1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: A perl *.sch to *.db converter (utility for capfast)
To: [email protected]
Date: Thu, 13 Jun 2002 12:33:49 +0200 (METDST)
I would like to announce Sch2db.pl. This is a perl-script
that converts capfast drawings (*.sch - files) directly to
the epics db-format (*.db files).
By using this script, sch2edif and e2db are no longer needed.
You can convert your capfast files without the need to have
capfast or the capfast license-server installed on your system.
However, this script needs the capfast symbol-files (*.sym). The
path to these files can be given on the command-line or can be
hard-coded into the script (look for "$opt_sympath"...).
The script has a short help-text which can be seen with
"./Sch2db.pl -h"
The no-defaults ("-n") option can be used in order to see
at a glance, what a capfast drawing really defines, by omitting
all default-values and just showing fields that are set to a
specific value. Together with "dbdiff" I use this to have a kind
of "diff" utility for capfast files.
Benjamin Franksen ([email protected]) has modified
"makeBaseApp.pl" here at BESSY in order to use Sch2db.pl instead
of sch2edif and e2db during make.
The script has been tested with most of the capfast-drawings here
at BESSY and converts them the same way the combination of
sch2edif and e2db does.
The script can be found at:
http://www-csr.bessy.de/~pfeiffer/perl/Sch2db.pl
I hope somebody finds this software useful.
Suggestions or comments are welcome.
greetings
  Goetz Pfeiffer            ([email protected])
Prev: Real-time data correlator ready for beta test Peregrine M. McGehee
Next: EPICS 3.14 question john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: A perl *.sch to *.db converter (utility for capfast) Redman, Russell O.
