During the compilation of EPICS R3.13.6 base software on Red
Hat Linux 7.3 I encountered a couple of problem.
1) -UDEBUG_PRINT=0 option crashes gcc/cpp.
Makefile.Host in src/ca includes the line:
USR_CFLAGS += -UDEBUG_PRINT=0
This compiler option, -UDEBUG_PRINT=0, crashes gcc on RH
7.3. Acually any option of the form "-U<macro>=<val>",
crashes gcc.
2) "int" instead of "osiSocklen_t" in
src/cas/io/bsdSocket/casIntfIO.cc.
In the file src/cas/io/bsdSocket/casIntfIO.cc,
a couple of variables are declared as "int" instead of
"osiSocklent_t". This causes "unable to promote "int" to
"socklent_t" " error with gcc on RH7.3.
We can avoid this error by declaring these variables
as osiSocklent_t.
*** io/bsdSocket/casIntfIO.cc 28 Sep 2000 10:50:45 -0000
1.4
--- io/bsdSocket/casIntfIO.cc 24 Jun 2002 04:57:19 -0000
*** 70,76 ****
int yes = TRUE;
int status;
caStatus stat;
! int addrSize;
if (!bsdSockAttach()) {
return S_cas_internal;
--- 70,76 ----
int yes = TRUE;
int status;
caStatus stat;
! osiSocklen_t addrSize;
*** 223,229 ****
struct sockaddr newAddr;
SOCKET newSock;
! int length;
casStreamOS *pOS;
length = sizeof(newAddr);
--- 223,229 ----
SOCKET newSock;
! osiSocklen_t length;
casStreamOS *pOS;
Noboru
[Q] How to set a timestamp in a device support routine. Noboru Yamamoto
Re: [Q] How to set a timestamp in a device support routine. Marty Kraimer
<2002>
2025
RE: [Q] How to set a timestamp in a device support routine. David H. Thompson
Re: [Report] EPICS R3.13.6 build on RH Linux7.3 Noboru Yamamoto
<2002>
2025
