1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Q] How to set a timestamp in a device support routine.
To: Carl Lionberger <[email protected]>
Cc: [email protected], "[email protected]" <[email protected]>
Date: Mon, 24 Jun 2002 12:46:15 -0500
Are you asking for something like
#define epicsTimeEventBestTime -1
#define epicsTimeEventDeviceTime -2
#define epicsTimeEventLinkPropagate -3
If it is then I suggest a slight change from what you recommended. The rules would be.
1) Transfering time stamps only works across database links.
2) dbScanPassive transfers the time stamp ONLY if the scanned record is passive.
   This replaces your suggestion to modify recGblFwdLink and dbScanFwdLink
3) dbPutLinkValue ??? What to do.
Output to asynchronous records are a problem (but always have been!!). The code is
if(plink->type==DB_LINK) { struct dbCommon *psource = plink->value.pv_link.precord; struct pv_link *ppv_link= &(plink->value.pv_link); DBADDR *paddr = (DBADDR*)(ppv_link->pvt); dbCommon *pdest = paddr->precord;
                status=dbPut(paddr,dbrType,pbuffer,nRequest);
                if(ppv_link->pvlMask&pvlOptMS)
                        recGblSetSevr(pdest,LINK_ALARM,psource->nsev);
                if(status) return(status);
                if((paddr->pfield==(void *)&pdest->proc)
                || (ppv_link->pvlMask&pvlOptPP && pdest->scan==0)) {
                        /*if dbPutField caused asyn record to process   */
                        /* ask for reprocessing*/
                        if(pdest->putf) pdest->rpro = TRUE;
                        /* otherwise ask for the record to be processed*/
                        else status=dbScanLink(psource,pdest);
When should the time stamp be transfered? I will say only when
Is successful. If this is not successfull then the put does not cause the record to process. In this case I see no reason to modify the time stamp.
Thus the problem comes down to the statements
In this case the put will cause the record to process but it may be delayed because an asyn record has not completed. If the time stamp is transfered before the above code then the asyn completion will have the new time stamp not the timestamp for the original request. If the timestamp is not transfered at this point there is no place to keep it. Also is it worse to replace the time stamp than to replace the VAL field? I don't think so. Thus perhaps the above code should be
if (paddr->precord->tse == epicsTimeEventLinkPropagate) paddr->precord->time = precord->time; /*if dbPutField caused asyn record to process */ /* ask for reprocessing*/ if(pdest->putf) pdest->rpro = TRUE; /* otherwise ask for the record to be processed*/ else status=dbScanLink(psource,pdest);
Marty Kraimer
Carl Lionberger wrote:
The diagnostic people here at SNS (where I'll be for the next couple of years,
right down the hall from David Thompson) have been asking for even more-  They want
time stamps to be able to propagate over forward links and, I assume for more
generality, dbPutLinks.  I start with the assumption of the code Marty gave(in my
working code I've been calling it "SPECIAL_TIME_EVENT" and making it -2) and then
have had several routines in dbAccess.c and recGbl.c propagate the time if its
set.  I've been working on a copy of 3.14.beta0.
From recGbl.c I have:
void epicsShareAPI recGblFwdLink(void *precord)
    struct dbCommon *pdbc = precord;
    static short    fwdLinkValue = 1;
    if(pdbc->flnk.type==DB_LINK ) {
        struct dbAddr   *paddr = pdbc->flnk.value.pv_link.pvt;
        if (paddr->precord->tse == SPECIAL_TIME_EVENT)
           paddr->precord->time = pdbc->time;
        dbScanPassive(precord,paddr->precord);
    } else
    if((pdbc->flnk.type==CA_LINK)
From dbAccess.c I have:
void epicsShareAPI dbScanFwdLink(struct link *plink)
    dbCommon            *precord;
    struct pv_link      *pvlink;
    short               fwdLinkValue;
    if(plink->type!=DB_LINK && plink->type!=CA_LINK) return;
    pvlink = &plink->value.pv_link;
    precord = pvlink->precord;
        DBADDR *paddr = (DBADDR *)plink->value.pv_link.pvt;
        return;
    if(!(pvlink->pvlMask & pvlOptFWD)) return;
    fwdLinkValue = 1;
    dbCaPutLink(plink,DBR_SHORT,&fwdLinkValue,1);
    return;
and:
long epicsShareAPI dbPutLinkValue(struct link *plink,
    short dbrType,const void *pbuffer,long nRequest)
        long            status=0;
                if (pdest->tse == SPECIAL_TIME_EVENT)
                    pdest->time = psource->time;
Note that I am not thinking to support channel access links or input links (hence I
don't put it in dbScanPassive).  There may be situations in which the target record
would not process at all or would be processing asynchronously and would just sit
there with the wrong time stamp -- this would be an unintended behavior that is not
excluded but could happen.  At least it would only happen if the target record had
this time event set.  Old databases would be unaffected.
So records with this event type set might get their time either from links that
caused them to process or from device support.  In general, the diagnostics team
wants to see chains of records, the first one of which would get the time stamp
from device support and subsequent ones would process it, keeping the same time
stamp.
Carl
Marty Kraimer wrote:
Someone else asked for this feature. I think the first person to ask was Timo
Korhonen (SLS) who is also the person who is redoing drvTS, which is the support
for hardware generated time stamps.
The next version of base (both 3.13 and 3.14) will provide this feature. The
exact method is still undecided. Corrently in my working area I have the
following change to recGbl.c
For 3.13
void recGblGetTimeStamp(void* prec)
   struct dbCommon* pr = (struct dbCommon*)prec;
   if(pr->tsel.type!=CONSTANT)
       dbGetLink(&(pr->tsel), DBR_SHORT,&(pr->tse),0,0);
   if(pr->tse!=-1)
       TSgetTimeStamp((int)pr->tse,(struct timespec*)&pr->time);
For 3.14 I have
void epicsShareAPI recGblGetTimeStamp(void* prec)
   int status = 0;
   if (pr->tse!=-1)
       status = epicsTimeGetEvent(&pr->time,(unsigned)pr->tse);
   if(status) errlogPrintf("%s recGblGetTimeStamp failed\n",pr->name);
The above change says that if TSE=-1 then dont do anyting to the time stamp.
This is NOT the final answer however. David Thompson (SNS) pointed out that the
existing drvTS already treats TSE=-1 as a special case. It means that drvTS
should get the most accurate current time stamp. For example with the APS
hardware time stamp support, we keep a 1 millisecond hardware generated clock.
If TSE=-1 then the time stamp will be taken from this clock rather than the
vxWorks 60 HZ clock.
Thus the above change to recGblGetTimeStamp is not correct. David suggested that
we define.
#define epicsTimeEventDeviceTime -10000
epicsTimeEventBestTime would be used by drvTS and it's successor.
epicsTimeEventDeviceTime says that device support is supplying the time stamp so
recGblGetTimeStamp should not do anything.
Questions to be resolved
1) Where do we define these? For 3.14 the obvious place is epicsTime.h. For 3.13
it is probably tsDefs.h
2) What value should we use for epicsTimeEventDeviceTime?
3) Whoever set the value for TSE must know about these values. How do we make
these values known? Just document them in the Application Developer's Guide?
Noboru Yamamoto wrote:
[Question]
Is there any good way to set a timestamp of a record while a
process() function of a device support routine is called?
[Why I'm asking this question]
We need to import live data from the facility control
system, which uses a proprietary control system. This system
update the information on the memory periodically with
theire own timestamp. We would like to use
this timestamp as a timestamp of EPICS records rather than
the timestamp when the record is updated.
Looking at aiRecord.c, for example, recGblGetTimeStamp is
called AFTER a call to read() function in a device support
is finished.
Any idea?
Noboru
Re: [Q] How to set a timestamp in a device support routine. Carl Lionberger
[Q] How to set a timestamp in a device support routine. Noboru Yamamoto
Re: [Q] How to set a timestamp in a device support routine. Marty Kraimer
Prev: mbboRecord - more than 16 states Marty Kraimer
Next: Re: [Q] How to set a timestamp in a device support routine. Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [Q] How to set a timestamp in a device support routine. Carl Lionberger
