1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: iocsh under Epics r3.14 RTEMS
To: [email protected]
Cc: [email protected]
Date: Wed, 10 Jul 2002 18:09:42 -0700
Hi Bill.
Finally some RTEMS posting :-)
Bill Nolan wrote:
Hi all, I've come to an interesting impass in trying to get the example IOC to start
using R3.14.beta1 and RTEMS. I hope the problem is that I'me being simple..
Drunig the boot sequence with rtems the Init() function is called from rtems_init.c to setup the network, time , syslog etc. in Init() iocsh("st.cmd")
is called. But Init() is called before main().
I slightly patched rtems_init.c so it calls main(). Note that the appended
patch also contains some other (small but important) fixes and workarounds
useful under RTEMS - some things have already been fixed, I had been
told, but probably are not in the distributed beta1 release yet.
What CPU/BSP are you using?
Regards
-- Till
so the app specific iocRegester calls are never made, Sould I cuntomize rtems_init.c for each app ? or export a replacement iocshRegisterRTEMS() ?
Thanks. Bill N.
[email protected]
The things you can't remember, tell the things you can't forget.
Index: RTEMS/base/rtems_init.c
RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/RTEMS/base/rtems_init.c,v
retrieving revision 1.1.1.1
diff -c -r1.1.1.1 rtems_init.c
*** rtems_init.c	2002/03/09 18:09:24	1.1.1.1
--- rtems_init.c	2002/07/11 01:00:13
*** 193,204 ****
--- 193,213 ----
      &rtems_bsdnet_config
+ #define DO_NORMAL_MAIN
   * RTEMS Startup task
  rtems_task
  Init (rtems_task_argument ignored)
+ #ifndef DO_NORMAL_MAIN
+ /* T. Straumann: invoke global constructors
+  *               from a task context...
+ extern void __do_global_ctors(void);
+     __do_global_ctors();
+ #endif
       * Create a reasonable environment
*** 207,224 ****
      putenv ("IOCSH_PS1=epics> ");
      putenv ("IOCSH_HISTSIZE=20");
       * Start network
      printf ("***** Initializing network *****\n");
      rtems_bsdnet_initialize_network ();
      printf ("***** Initializing TFTP *****\n");
      rtems_bsdnet_initialize_tftp_filesystem ();
      for (;;) {
          printf ("***** Initializing NTP *****\n");
          if (rtems_bsdnet_synchronize_ntp (0, 0) >= 0)
              break;
!         epicsThreadSleep (10.0);
      printf ("***** Initializing syslog *****\n");
      openlog ("IOC", LOG_CONS, LOG_DAEMON);
--- 216,239 ----
+ 	/* T. Straumann: epicsThreadSleep() doesnt work before clockInit() */
+ 	clockInit();
       * Start network
+ 	printf ("\nWelcome to EPICS on RTEMS\n");
      for (;;) {
+ 		double sl=10.0;
              break;
! 		printf("SLEEP %g\n",sl);
!         epicsThreadSleep (sl);
*** 230,235 ****
--- 245,251 ----
      printf ("***** Executing EPICS startup script *****\n");
      iocshRegisterRTEMS ();
      rtems_set_directory ();
+ #if 0
      iocsh ("st.cmd");
*** 237,242 ****
--- 253,272 ----
      epicsThreadSleep (2.0);
      iocsh (NULL);
+ #else
+ #ifdef DO_NORMAL_MAIN
+     char *args[]={"iocsh","st.cmd"};
+     main(2,args);
+ #else
+     extern int rtems_main(int, char **);
+     rtems_main(2,args);
+ #endif
+ #endif
      LogFatal ("Console command interpreter terminated");
Index: RTEMS/base/rtems_netconfig.c
RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/RTEMS/base/rtems_netconfig.c,v
retrieving revision 1.2
diff -c -r1.1.1.1 -r1.2
*** rtems_netconfig.c	2002/03/09 18:09:24	1.1.1.1
--- rtems_netconfig.c	2002/03/09 19:08:38	1.2
*** 44,49 ****
--- 44,52 ----
  #else                                    /* Use NIC provided by BSP */
  # define NIC_NAME   RTEMS_BSP_NETWORK_DRIVER_NAME
  # define NIC_ATTACH RTEMS_BSP_NETWORK_DRIVER_ATTACH
+ /* T. Straumann, TSILL, 12/18/2001, added declaration, just in case */
+ extern int
+ RTEMS_BSP_NETWORK_DRIVER_ATTACH();
  #endif
  static struct rtems_bsdnet_ifconfig netdriver_config = {
Index: libCom/cxxTemplates/tsFreeList.h
RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/libCom/cxxTemplates/tsFreeList.h,v
*** tsFreeList.h	2002/03/09 18:09:30	1.1.1.1
--- tsFreeList.h	2002/04/05 00:52:34	1.2
*** 74,81 ****
  template < class T, unsigned N = 0x400, unsigned DEBUG_LEVEL = 0u >
  struct tsFreeListChunk {
!     tsFreeListChunk < T, N, DEBUG_LEVEL > *pNext;
      tsFreeListItem < T, DEBUG_LEVEL > items [N];
--- 74,84 ----
!     /* Till Straumann <[email protected]>, 2002/4/4
!      * put the items first to maintain alignment.
+     tsFreeListChunk < T, N, DEBUG_LEVEL > *pNext;
Index: libCom/osi/os/RTEMS/osdPoolStatus.c
RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/libCom/osi/os/RTEMS/osdPoolStatus.c,v
*** osdPoolStatus.c	2002/03/09 18:09:31	1.1.1.1
--- osdPoolStatus.c	2002/03/09 18:38:31	1.2
*** 8,12 ****
--- 8,17 ----
  epicsShareFunc int epicsShareAPI osiSufficentSpaceInPool ()
+ /* T. Straumann: 2/12/2002 the current RTEMS implementation
+                  of this has a serious flaw (killing
+                  real-time responsiveness!!!)  DONT USE
      return (malloc_free_space() > 100000);
+     return 1;
Index: libCom/osi/os/RTEMS/osdThread.c
RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/libCom/osi/os/RTEMS/osdThread.c,v
*** osdThread.c	2002/03/09 18:09:31	1.1.1.1
--- osdThread.c	2002/03/09 18:52:38	1.2
*** 118,131 ****
  unsigned int
  epicsThreadGetStackSize (epicsThreadStackSizeClass size)
      switch(size) {
!     case epicsThreadStackSmall:  return( 4000*ARCH_STACK_FACTOR);
!     case epicsThreadStackMedium: return( 6000*ARCH_STACK_FACTOR);
!     case epicsThreadStackBig:    return(11000*ARCH_STACK_FACTOR);
      default:
          errlogPrintf("epicsThreadGetStackSize illegal argument");
!     return(11000*ARCH_STACK_FACTOR);
--- 118,136 ----
  unsigned int
+ unsigned int rval=(11000*ARCH_STACK_FACTOR);
+ /* T. Straumann: make sure we allocate at least RTEMS_MINIMUM_STACK_SIZE */
      switch(size) {
!     case epicsThreadStackSmall:  rval = ( 4000*ARCH_STACK_FACTOR); break;
!     case epicsThreadStackMedium: rval = ( 6000*ARCH_STACK_FACTOR);
!     case epicsThreadStackBig:    break;
      default:
+ 	break;
!     if (rval < RTEMS_MINIMUM_STACK_SIZE)
!     	rval = RTEMS_MINIMUM_STACK_SIZE;
!     return rval;
*** 261,267 ****
      if (!initialized) epicsThreadInit();
      if (stackSize < RTEMS_MINIMUM_STACK_SIZE) {
          errlogPrintf ("epicsThreadCreate %s illegal stackSize %d\n",name,stackSize);
!         return 0;
      strncpy (c, name, sizeof c);
      sc = rtems_task_create (rtems_build_name (c[0], c[1], c[2], c[3]),
--- 266,274 ----
!         /* T. Straumann: just increase the stack size */
!         /* return 0; */
!         stackSize=RTEMS_MINIMUM_STACK_SIZE;
iocsh under Epics r3.14 RTEMS Bill Nolan
Prev: iocsh under Epics r3.14 RTEMS Bill Nolan
Next: Re: iocsh under Epics r3.14 RTEMS Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
