>>>>> "Rok" == Rok Sabjan <[email protected]> writes:
> Hi to everybody!
> I'm having a peculiar problem. I have a number of strings (around 50) and
> I would like to display one of them, depending on number parameter. This
> is no problem with numbers, as sel record can be used. The amount of
> strings also does not allow the usage of mbbi record.
> Any suggestions?
> Thanx.
What I did in a similar case was a database solution:
- The 50 strings are kept in a number of stringout records, which all
point their OUT links to a single stringin (or stringout) where the
selected string should appear. (This is where the clients point to.)
- The string selection number is written into a calcout record input
- The calcout record calculates NUMBER MOD 10 and writes NUMBER DIV 10
to the SELN field of a coarse selector seq record.
- This coarse selector seq record runs in 'Specified' mode and transfers
the calcout's VAL (i.e. the offset inside the fine selector seq) to
one of the fine selector seq records.
- The affected fine selector seq record runs also in 'Specified' mode
and just triggers the correct string container record that overwrites
the string in the destination.
Since the seq record has 10 links this two-step selection allows to
select one from up to 100 strings to be written into a single string
record. If you have more strings you will have to add a third selection
level.
Hope this helps,
Ralph
- Re: sel record for strings Rok Sabjan
- sel record for strings Rok Sabjan
<2002>
2025
<2002>
2025
