1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ISEG VHQ204L Driver (Really: PPC and VME)
To: "'Andrew Johnson'" <[email protected]>, Kay-Uwe Kasemir <[email protected]>
Cc: "Burkhard W. Kolb" <[email protected]>, [email protected]
Date: Thu, 25 Jul 2002 14:14:12 -0700
For this problem of forcing instructions to occur in the order that
they appear in the code, I've used the asm instructions as well. To make
maintenance a bit easier I defined macros. Some but not all bsp's come with these
macros already. If not in a header file you may find it in some of the vxWorks source
for a bsp.
#define EIEIO       __asm__ volatile ("eieio")
#define EIEIO_SYNC  __asm__ volatile ("eieio;sync")
#define SYNC        __asm__ volatile ("sync")
Can you please send any fixes to the code back to me so that I can add these  changes.
 - Regards,
     Kristi
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Thursday, July 25, 2002 9:14 AM
> To: Kay-Uwe Kasemir
> Cc: Burkhard W. Kolb; [email protected]
> Subject: Re: ISEG VHQ204L Driver (Really: PPC and VME)
> Kay-Uwe Kasemir wrote:
> > Sounds like another way of forcing electrons out of the CPU
> > - if not even better than __asm__ volatile ("sync").
> eieio is likely to be quicker - IIRC the sync causes the instruction
> pipeline to be stalled until the write is done as well, which isn't
> strictly necessary in this case (but useful when installing new CPU
> instructions).
> > But what about the Universe II chip on most PPC boards
> > which has its own write pipeline?
> > Is there a "flush" register/command on it?
> IIRC there's a bit somewhere that claims to show whether the write
> pipeline is empty, but when I tried putting code into the Universe
> interrupt handler to wait for this after running each ISR it made no
> difference to the "bad vme interrupt 0" error messages we
> were getting.
> The dummy read is the correct technique, as it also works on
> the Motorola
> 68K boards that have a VMEchip2 if that's set to do write pipelining.
> > (2) the fact that the memory regions mapped to VME are
> configured as "not cacheable"
> >     in the vxWorks BSP's sysPhysMemDesc
> BTW, I also mark our VME regions as Guarded, which supposedly
> prevents the
> CPU from changing the order of writes to that address region.  I'm not
> sure if it makes any difference IRL, but it certainly makes me happier
> after having read about the possibility.
> - Andrew
> Larry McVoy: "Learn how to think in C++ but don't ever program in it."
Prev: epicsBase3.13.7 Marty Kraimer
Next: GPIB driver & device support update Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: building SDDS.1.21.1 on Solaris 2.8 Lei Ge
