1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: ca_array_get_callback LOCK
To: <[email protected]>
Date: Thu, 1 Aug 2002 11:55:54 -0700
I've written a CA client that calls ca_array_get_callback in a loop to get a
few PVs. I've been testing the client's ability to reconnect to the server
by rebooting the IOC while the client is running.
What I find is that if the client loops too fast (< 100ms) and I reboot the
server that the client will report 'no callback' for 5 seconds (as it
should) but then get a run-time error with the message:
	a call to "assert (status == S_bucket_success)" failed in
\epics\base\src\ca\access.c line 1490 (version R3.13.5)
It seems that once ca recognizes that the connection is lost, an attempt is
made to remove the caIOBlock from a list but the removal fails. The stack
trace looks like this:
caIOBlockListFree(ELLLIST * 0x00885210, channel_in_use * 0x0088bfe8, int 1,
int 192) line 1508
cacDisconnectChannel(channel_in_use * 0x0088bfe8) line 1533 + 26 bytes
cac_close_ioc(ioc_in_use * 0x00e90198) line 1462 + 9 bytes
checkConnWatchdogs(unsigned int 1) line 142 + 9 bytes
cac_mux_io(timeval * 0x0012fd5c, unsigned int 1) line 2115 + 9 bytes
cac_block_for_io_completion(timeval * 0x0012fd5c) line 240 + 11 bytes
ca_pend(double 0.00050000002374873, int 0) line 2912 + 9 bytes
 * caIOBlockFree()
void caIOBlockFree(miu pIOBlock)
	int	status;
	LOCK;
	status = bucketRemoveItemUnsignedId(
			ca_static->ca_pFastBucket,
			&pIOBlock->id);
	assert (status == S_bucket_success);
	pIOBlock->id = ~0U; /* this id always invalid */
	freeListFree(ca_static->ca_ioBlockFreeListPVT, pIOBlock);
	UNLOCK;
Could it be that there's a potential race between checkConnWatchdogs and
ca_array_get_callback over a list of caIOBlocks? I notice that both routines
are bracketed with LOCK/UNLOCK (which I guess arent implemented for most
OSs).
I've only seen this happen with Windows.
Chris Timossi
LBNL
RE: ca_array_get_callback LOCK Jeff Hill
Prev: Epics Base R3.14.0beta2 Marty Kraimer
Next: RE: ca_array_get_callback LOCK Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
