1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: "moving" N to 1 compression records
To: [email protected]
Date: Thu, 08 Aug 2002 14:49:39 -0600
The standard (R3.13.5) compression record only performs
N to 1 actions (low, high, average, median) when the
circular buffer fills.
Before I make a site-specific mod to the compress_scalar()
routine does anyone have a solution that computes
"moving" averages and low/high values?
	Peregrine
Peregrine M. McGehee	[email protected]	(505) 667-3273
Sloan Digital Sky Survey / Spallation Neutron Source
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
Prev: EPICS Base License for SLAC - problems, apologies, and thanks Allison, Stephanie
Next: Testing tech-talk Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: "moving" N to 1 compression records Andrew Johnson
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
