1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Passing large arrays over channel access with R3.14b2
To: [email protected]
Date: Wed, 14 Aug 2002 07:50:55 -0500 (CDT)
Greetings,
lient Xterm. When I attempt to run an SDDS tool to read the waveform, I get the following error message:
CA.Client.Diagnostic..............................................
    Message: "The array or data structure specified will not fit in CA message buffer"
The environment variables on my ioc are as follows:
epics> epicsPrtEnvParams
EPICS_AR_PORT: 7002
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_INTF_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_ADDR_LIST: 164.54.189.255
EPICS_CA_AUTO_ADDR_LIST: YES
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_MAX_ARRAY_BYTES: 512000
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CMD_PROTO_PORT is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_TIMEZONE: CUS::360:033102:102802
EPICS_TS_NTP_INET is undefined
Any ideas?
S. Joshua Stein
APS/ASD - Controls
630-252-4105
[email protected]
RE: Passing large arrays over channel access with R3.14b2 Jeff Hill
Prev: alarm handler john sinclair
Next: Large arrays over CA - attempt #2 S. Joshua Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: alarm handler Ralph . Lange
Next: RE: Passing large arrays over channel access with R3.14b2 Jeff Hill
