1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access to device support debugging vars via iocsh (3.14b2)
To: Tim Mooney <[email protected]>
Cc: "S. Joshua Stein" <[email protected]>, [email protected]
Date: Mon, 19 Aug 2002 16:27:18 -0500
Tim Mooney wrote:
> "S. Joshua Stein" wrote:
> > I would like to set a (global) debugging variable which is part of my device
> > support running on a solaris IOC (3.14b2). In the vxWorks world, I would just
> > type:
> > >deviceDebugVar=1
> > This, however, won't work with iocsh. Does anyone know if/how I can gain access
> > to these variables?
> How about connecting an AO record to the global symbol, using devAoSymb
> device support?
> Then you could set the variable from any CA client.
That relies on someone having converted the vxWorks symbol support to use
the R3.14 symbol registration routines (which I don't believe has been
done yet, but I might be wrong there), and Josh would still have to
register the address of his debug variable with the registration
facility.  It should be possible to do that within a device support
initialization routine rather than having to write the C++ static
initializer routine that Eric was describing, but Eric's solution is
probably simpler overall until vxSymb gets properly converted to R3.14.
- Andrew
Edsger W. Dijkstra, 1930-2002: "The use of COBOL cripples the mind;
its teaching should, therefore, be regarded as a criminal offence."
Access to device support debugging vars via iocsh (3.14b2) S. Joshua Stein
Re: Access to device support debugging vars via iocsh (3.14b2) Tim Mooney
Prev: Re: Access to device support debugging vars via iocsh (3.14b2) Tim Mooney
Next: Re: Access to device support debugging vars via iocsh (3.14b2) Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
