1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subRecord fix
To: Till Straumann <[email protected]>
Cc: [email protected]
Date: Tue, 20 Aug 2002 17:32:29 -0500
Till Straumann wrote:
I don't know if this has been fixed already...
If you look at the top of the init_record() routine, you'll see that it only gets that far down the routine when pass==1, so there would be no point passing pass anyway.
The second argument to the init subroutine has been the address of the record's process routine since CVS records began (R3.12.2). Why did you think it should be the pass (is there some documentation somewhere that implies this? I have a vague feeling I've seen something, but it's not the record reference manual which doesn't even list a second argument to the initialzation subroutine).
- Andrew
Edsger W. Dijkstra, 1930-2002: "The use of COBOL cripples the mind;
its teaching should, therefore, be regarded as a criminal offence."
subRecord fix Till Straumann
Prev: subRecord fix Till Straumann
Next: Labview <-> EPICS Mark M. Ito
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: subRecord fix Andrew Johnson
