1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: timestamp question
To: Kevin Tsubota <[email protected]>
Cc: "EPICS-tech-talk (E-mail)" <[email protected]>
Date: Tue, 27 Aug 2002 07:07:34 -0500
Does your application call gettimeofday to get the time stamp?
If so it uses seconds since the UNIX epoc (1970) and microseconds within the second. Another, less likely, possibility is that your application calls clock_gettime, which uses seconds since the POSIX epoch (1970) and nanoseconds within the second. Another possibility is that your application calls time which just returns seconds since 1970.
For EPICS call tsLocalTime for 3.13 or for 3.14 call epicsTimeGetCurrent.
Marty Kraimer
Kevin Tsubota wrote:
Hi All,
I have a channel access application that we inherited from someone else a
long time ago that is returning a timestamp of seconds since 1/1/1970. This application also has
its own camonitor
utility that returns the current date. However when I use the base
camonitor I get timestamps 20yrs
in the future.
Upon further investigation I found comments that EPICS uses 1/1/1990 as its
epoch. So I'm guessing
here that EPICS camonitor is taking the timestamp from my application and
adding 20yrs. Is this
correct or am I _way_ out in left field?
Thanks in advance.
Kevin
Code snippet from EPICS R3.13.0Beta12/base/include/tsDefs.h
* TS_STAMP
*    This is the form taken by time stamps in GTACS, and is the form used
*    by the various tools used for dealing with time stamps.
*    The time stamp represents the number of nanoseconds past 0000 Jan 1,
199
0,
*    GMT (or UTC, if you prefer).
typedef struct {
    epicsUInt32    secPastEpoch;   /* seconds since 0000 Jan 1, 1990 */
    epicsUInt32    nsec;           /* nanoseconds within second */
} TS_STAMP;
timestamp question Kevin Tsubota
Prev: timestamp question Kevin Tsubota
Next: RE: timestamp question Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
