> We are considering an upgrade to our systems to use the Power PC range
> of VME CPU cards . So the question is which VME CPU cards do EPICS
> users use?
> Which are most compatible with the EPICS software?
> thanks for the replies
> regards
Dennis,
The Fermilab D0 experiment successfully uses MVME2301, MVME2304, and
MVME2604 processor boards -- we have ~100 PPC processors in the D0
control system. Depending upon your application, there may be other
MVME-series PPC boards that would better suit your purposes (i.e. a
better performance/price ratio). Keep in mind that these boards can
not be field-upgraded to add memory; so, when you estimate your memory
requirements, allow for sufficient expansion -- EPICS data structures
tend to be large. I usually purchase boards with at least twice the
memory that I estimate will be initially required.
We also have MVME162 processors (M68K family) and the same C and C++
source code builds for both processor families (with one or two
conditional sections).
Fritz Bartlett
- RE: Recommendations for Power PC VME cards David H. Thompson
- Recommendations for Power PC VME cards Dennis Armstrong
re: simulation mode Laznovsky, Michael
Re: old/new MVME-177 compatability Graham Waters
<2002>
<2002>
