1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800
To: Jim Thomas <[email protected]>
Cc: [email protected], [email protected], Ned Arnold <[email protected]>
Date: Thu, 31 Oct 2002 17:39:09 -0600
Jim Thomas wrote:
"Ned" == Ned Arnold <[email protected]> writes:
Ned> The short answers are ...
>> From: "Redman, Russell O." <[email protected]>
>> My big questions are thus
>> 1) Under what circumstances does pushing a value over a CA link cause the
>> target record to process?
 Ned> .... if the destination field is defined as "PP" (with the statement
 Ned> "pp(TRUE)" in the *.dbd file and so documented under the PP column in
 Ned> the record reference manual) and the record scan field is set to
 Ned> "Passive". If these two conditions are true, the record will process
 Ned> when ANY channel access client (including a sequence programs, CA
 Ned> links, etc) writes to that field.
So it is a record type property?  There is no way to vary it per record
instance?
Yes and yes.
Implication -> more special record types :-(
Not necessarily; if it's important in some particular circumstance to use the "other" setting for a field, you can always put an AO or similar record in the way with a DB link on its OUT field set to PP or NPP as required. I've never heard of anyone producing a new version of a record type just to change a PP setting, although I suppose it could happen...
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800 Ned Arnold
Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800 Jim Thomas
Prev: Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800 Jim Thomas
Next: Re: When does a link process its target record? Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: When does a link process its target record? Redman, Russell O.
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
