>>> On 11/7/2002 at 11:15:21 CST, Ned Arnold wrote:
> 2) If you can do without strings, use a longout record that can then
> fanout to calc records and mbbo's to determine the appropriate action.
If the selection you want is done by setting 22 individual *bits* (rather
than 22 *values*), there should be an alternative using the mbboDirect
record, working through the fields for the individual bits.
Unfortunately, when mbboDirect was created from mbbo, VAL was defined as
DBF_USHORT, instead of DBF_ULONG, and only 16 bit fields were added. I've
thought about adding another 16 bit fields (using B10 -> B1F so the
existing field names don't have to change), but I'm not sure of the
consequences of changing VAL from SHORT to LONG for existing clients.
Brian McAllister Controls Programmer/Beam Physicist
[email protected] MIT-Bates Linear Accelerator
(617) 253-9537 Middleton, MA
- Re: Extending MBBO? Ned Arnold
Re: Extending MBBO? Ralph Lange
Use of AutoReply Ralph Lange
<2002>
2025
RE: Extending MBBO? Owens, PH (Peter)
<2002>
2025
